Replacing the Driveshaft – 2001 4runner 2wd w/ Pics
Beach4RunnerNC
Hey guys, the difficulty of this project would be a 2/10. If you can change a tire you can do this job. To skip my life story, jump down to the pics below to begin the tutorial.
New member here. I’m a long time lurker of this and many other 4runner forums. I recently purchased a 2001 4runner 2wd, sport package with 160k on the clock. I’ve been going through the motions doing a few of the recommended updates and maintenance.
About a week ago I began having a bad vibrations in my shifter when accelerating accompanied by an overall loss of power. According to online comments, worn u-joints display these symptoms when beginning to fail. Upon inspecting mine, the rear joint was clearly busted. At one of the ends of the joint, several small metal rod bearings were making their way out of the rubber covering. Failure of the joint was imminent.
As it is never a good idea to drive a broken vehicle, I took the car to the shop. Their diagnosis though was a little different. They confirmed that my rear u joint was worn but in addition my drive shaft was bent. Since they weren’t busy that morning and I was waiting in-shop for my ride, they were able to bring me to the back and show me the problem. On the lift with the car running (and drive shaft spinning), it was clear that there was about a ¼ - ½ inch ‘wobble’ at the rear third of the shaft. This wobble was the source of the vibrations.
They quoted me the cost to repair... $850!! A little more than the $220 I had been quoted to replace the u joints. I knew the part needed to be repaired, having inspected the wobble first hand. But in the meantime, I had to get back to work. So a friend picked me up, and I told them to put it on hold and I would think it over and get back to them asap. I knew I wasn’t ready to spend that kind of money, so I hopped online and started looking for DIY guides and a replacement shaft.
I learned a few things in the process: for one, the 2wd 4runners have a different drive shaft than the 4wd versions. The 2wd version has a single-piece, straight tube design. It is a 'slip-yoke' drive shaft, meaning that the front connection slips on to the male end of the transmission, without the need for fasteners (See pic). The rear end of the shaft is then fastened by four 14mm bolts.
Luckily, there are a few good video walk-throughs for similar drive shafts. They can be found here:
Replacing a Rear Axle U Joint : Installing a Drive Shaft to the Transmission - YouTube
Driveshaft REMOVE and INSTALL how to - YouTube
Next I needed to find the part. According to the guy at the shop, the replacement drive shaft made up $750 of the total repair cost, i believe they were going straight to the Toyota dealer for it, OEM. I was able to find a replacement online for $350, with tax and shipping. With this information, I decided I would be doing the job myself!
The only thing left to do was bolt it on.
So now what you’ve all been waiting for:
You will need the following items for this job:
2 Jack stands
1 Lift
2 Tire stops (I used two pieces of wood)
2 14mm box wrenches
1 13-15mm box wrench or similar size to add leverage to your 14mm wrench (see below)
1 Rubber mallet
1 Flat-head screwdriver
Tip: It is always a good idea to fully research a project and gather any necessary materials before beginning. Always inspect the replacement part to make sure it matches your vehicles part before disassembling anything.
Step 1: Put your vehicle in park with the e-brake on. Put tire stops behind the front tires. Next, put the rear axle on jack stands. You need both wheels off the ground, so that they can spin freely when the vehicle is
in neutral.
IMG_3654.jpg~original
Step 2: Loosen the two accessible bolts on the drive shaft's rear joint. You will only be able to reach two of the four. You will likely need to use a second wrench and 'hook' it on your 14mm wrench to break the bolt free. Only break them loose, do not remove them.
IMG_3675.jpg~original
(Pic is on the new shaft, for illustrative purposes)
‘Hooking’ the wrenches:
IMG_3660.jpg~original
Step 4: Put the car in neutral and release the e-brake. Go under the car and turn the drive shaft to expose the other two bolts.
Step 5: Put the car back in park with e-brake and break loose the two other bolts in the same fashion. Fully remove the bolts.
Step 6: Put the car back in neutral. Turn the drive shaft back to the two remaining bolts and fully loosen them, but do not remove. Take your rubber mallet and strike the joint till it breaks free from the rear differential. Be careful to fully support the shaft so that it doesn’t fall. Remove the bolts and set the rear on the ground.
Rear differential with drive shaft removed:
IMG_3664.jpg~original
Step 7: With the rear of the drive shaft on the ground, slowly slide out the front yoke out. Some ATF fluid will drip out, this is normal. Inspect for discoloration.
IMG_3655.jpg~original
Step 8: Inspect the old shaft and compare to the new one. It was apparent that my rear joint was shot. The way to tell is that each joint motion should move freely, or else its bad. The front end would move side to side each way with ease. The rear would not budge in one direction.
IMG_3670.jpg~original
IMG_3671.jpg~original
Area where rod bearings were escaping.
IMG_3681.jpg~original
Step 9: Remove the guard piece for the front yoke from the old drive shaft and replace on the new. This is where the screwdriver comes in. Use it to pry the old one off. I had to hit it with the rubber mallet to start it then slowly wedge around. Took a minute. Replace on the new one by evenly beating it on with the rubber mallet.
IMG_3683.jpg~original
IMG_3685.jpg~original
Step 10: Reassemble. The front yoke will slide right in. Since this is a complete replacement, it doesn’t matter how the yoke goes in. Some drive shafts are ‘keyed’ and have a missing spline or ridge in the yoke which needs to be matched up. 2wd 4runners don’t have this. I’m not sure about 4wd.
Splines:
IMG_3657.jpg~original
Yoke in:
IMG_3744.jpg~original
The vehicle should still be in neutral. Turn the diff to line up the holes with the rear of the shaft and insert the bolts. Don’t forget to use loc-tite! Hand tighten each of the four bolts.
IMG_3673.jpg~original
Step 11: Put the car in park and e-brake on. Tighten the two visible bolts. Service manual states that the recommended torque specs are 54 ft/lbs. I did the double wrench trick and tightened as much as I could. I did not have room to use a torque wrench.
Step 12: Put the car in neutral and turn the shaft to the other two bolts. Reapply park and e-brake. Torque the remaining two bolts.
IMG_3678.jpg~original
Step 13: Put the car back in neutral (you tired of this yet?) and inspect the rear joint. The joint should be flush with the rear diff on all sides. Take her for a test drive.
Fully installed:
IMG_3746.jpg~original
Congratulations, you now have fully replaced your drive shaft! Crack a cold one if you haven’t already.
In retrospect it may be better to take the time to torque the four bolts in a criss-cross manner. After driving the vehicle it does have slightly better response than the previous one even when it was working properly. When comparing the two shafts, the new one seemed to be a bit lighter than the old one. The old is the original, the new is a re-manufactured replacement. It is still made of steel and not aluminum I believe, but any less weight should add some efficiency. Also, a big thanks to DriveShaft Power, Inc. in Lake Worth, FL, I ordered from them on Wednesday morning and it was at my door Friday evening.
Hopefully, this guide will convince others to tackle this project themselves.
Good job. I was a little apprehensive when I took off my first drive shaft; I almost forgot to make a match mark for reinstallation after a U-joint replacement.
I was somewhat apprehensive because it is such an integral piece of the car, but after researching it, there wasn't much i could mess up. I did forget to put on the front yoke guard piece the first time and had to reinstall it. That made writing the guide a little easier!
I'm not sure why the shaft has to be marked for alignment against the rear diff though. I know it is not necessary when installing an entirely new shaft, but for the u joints? as long as the shaft is reassembled in the same way, i don't see why it would have to be bolted on in a specific way. Maybe the 4wd version is different?
Wouldn't it have been cheaper to replace the u-joints rather then the whole shaft?
Great write up. i use the cheater wrench all the time.
Yes, it would have been. But according to the shop and my observation, the drive shaft was bent. It is possible that the amount of wobble was normal, but with the drive shaft costing 350$ and the joints installed at the shop being 220$, i think i made out alright replacing the entire thing.
So you used a 4wd model driveshaft or did I misinterpret that. It looks awfully shorter.
It's not a 4wd driveshaft. But it is definitely shorter than the OEM driveshaft. I hope it's long enough that the slip yoke won't slide out of the trans completely, while driving down the road and hitting a bump that compresses and then fully extends the rear suspension.
I'd be inclined to measure the length of the OEM driveshaft, and send the new one back to be lengthened, or just replaced with one of the correct length.
It might seam shorter but the photograph is turn side ways and it is photographed at an angle. So the one in the back would appear smaller.
Yes, I noticed that too before replying. The new driveshaft still appears to be shorter. I'd still measure both to be sure.
Hey guys, thanks for keeping a good eye, but the two shafts are the same size, end to end. The photo is misleading for a couple of reasons. First, the old shaft still has the tranny guard on it. Second, the new shaft doesn't appear to be the exact same design as the original one. The joints are larger on the oringinal, and the u joint clips are different. The picture was also taken on a hill which doesn't help.
Here are couple more pics to show the difference:
Front
IMG_3672.jpg~original
Rear
Rotated
Also heres a pic of the splines, if anyone cares
IMG_3668.jpg~original
I'm glad to hear it. I looked at the pic for quite awhile, and wondered if it might just be how the driveshafts were situated in the pic, but decided to reply in case they weren't the same length.
I've seen more than a few driveshafts that were built to the wrong specs, and caused some serious problems.
I'm relieved that wasn't the case here. Congrats on getting the 'Runner back up and running. :thumb3:
YES!! Another 2wd!! lol
Nice read you have there as well! A little question. How long is it going to stay shinny and new? lol
02SE: Yeah i definitely made sure they were the same length. I changed one of the pics in the tutorial that shows the front when installed; with the tranny guard on it mates perfectly with the transmission.
02 SE Runner: Thanks, hopefully it stays shiny for a while! I don't do much wheeling. This is my daily driver and she stays on the road 95% of the time except for the occasional gravel road. All we have is sand around here which is sometimes even tough for 4wd vehicles.
I spoke to the rep from the company i purchased the shaft from today. I wanted to know what type of grease they use for the joints. He said they use some heavy duty stuff called Castrol Blue Pyroplex or something like that. It is high temp grease and used in commercial applications. He said any typical ford motor grease with high temp ratings would work.
They recommend regreasing every 5k miles but he said it could be much more and that # was for liability reasons.
Also something interesting he mentioned was that the stock toyota shaft is a 'shaft-in-shaft' type which, as you can see in the pictures, is made up of one shaft in another. He said that there is a rubber bearing or bushing between the two that can wear out over time and may have been a cause for how mine bent.
Can you please tell me where you ordered your driveshaft online. I have checked around here and only one place can "rebuild them" and online I have found alot of places that don't look very legit and only one that looks normal but I can't find anything on the reputation. Sorry I'm looking for my husband who knows the problem and I'm just the "finder"...Thank you for the pictures and all of the information so far.... :
I dont see how a driveshaft could go bad? I would have just replaced the u-joints, I did my rear one and i think it was about $10 and took about 30min. no way would I have paid someone 200 or order a new driveshaft.
There are quite a few places you can find online that will build a new drive shaft. Most notable is Tom Woods... Very well known with a stellar reputation.
Tom Wood's Custom Drive Shafts - Tom Woods Custom Drive Shafts Custom Driveshafts Specialist
No experience with this company...
Toyota 4x4 Truck driveshaft, constant velocity repair kit, u-joints, flanges, h-yokes, front driveshafts
Your best bet is to search locally. I had one built locally that set me back $450. Cheaper than new OE, and serviceable.
If you have a 4wd, I can get the part numbers from my receipt for the one I had built. Ive been able to find most all of the individual parts at various places online.
OP stated his drive shaft was bent. Thread is over 1 year old.
2001ATL
