replacing the x-reas
Jesman
It's soon time to replace the shocks on my 07 sport. It is my daily driver and I use it as my utv tow vehicle once a month and for 2 separate weeks a year. It doesn't see much off road use. That's what the RZR is for. I'm thinking the biltsteins for the front so I can level it. What can I use in the rear to keep it level when towing? Is there something available that I can adjust to keep it level when towing? I will also be getting new wheels and tires. For wheels it will most likely be TRD 17s. For tires I would like to go up a size or two. What are my options for the rear suspension?
i would think bils all around, and also use some airbags in the rear coil. firestone uses compression type fittings while airlift use the clamp type. so far with the firestone i have had no problems of leaking air.
I towed my cargo trailer with 4 ATVs inside with my last 4runner. It had Bilsteins all around and Toytec rear coils. It didn't feel nose light or squat in the rear much an probably carried 600 lbs tongue weight. Not sure you will need rear bags.
H.Sikina
