Replacing tires...
sharp4runr
Ok, this may be a stupid question to some but I'm just not sure so I'm asking.
When you change out the tire, it shouldn't affect the TPS right? All that would be replaced is the tire and the valve stem? Would anything special need to be done to replace tires?
July
TPS...
The Tire Pressure Monitoring Sensor (TPMS) is integral with the valve stem so there is no need to replace the "stem". Just swap tires, inflate, balance and you're good to go!
