replacing Xreas...
I might be repeating myself... but just make sure the shops knows if they let the front suspension droop down when they pull the the coil-over-shock there is a good change the ABS speed sensor harness will stretch and break. $130 for the parts alone but fairly easy DIY to fix.
I really like how the 5100s ride even with the worn OEM springs.
CEH in MD
2005 Limited V8 220,000 miles.
i've done a search, but could not get a real answer to the question, here it is:
i'm most likely going to replace the xreas with a regular shock/suspension setup. I want to replicate or improve the ride quality i had with Xreas, that is softness and handling on the road. I do very little offroading, so lifts/offroad capability don't mean much to me. I use the truck for mostly hwy driving,
thanks in advance
I just replaced my XREAS with bilstein 4600s at 160,000 miles
I just bought a 04 SE V8 with 210k miles, curious about my shocks...do you like the Bilstein 4600's you used?
