mikestang said:
Expat said:Just so there's no confusion, that's the same procedure as I posted in my reply which is posted here on T4R.
sjm1027 said:Oil change was 14mm for the oil drain and 5.5 quarts . The only pain was the tube under the oil catch in the filter area. That setup sucks... we need to design something better
Maintenence light has been reset!
Thanks everyone
Steve![]()
NoIcepuck72 said:So I'm searching this topic because my wife calls me and tells me the maintenance light is on.
I just changed the oil....but is the maintenance light the same as the check engine light??
Yes - to remind you to change the oil. It's documented in the owners manual -- offhand, I don't remember the mileage that triggers it, but think it's around 5,000 miles and 7,500 miles. The function has two stages -- the MAINT light stays on a bit longer at startup initially (5,000 miles), then it stays on constantly at a higher mileage (7,500 miles).Does the maintenance light come on at certain intervals to remind you to do some work?
Thanks!JP4RNR said:It's every 4500 Miles to be exact
4bummer said:tell your wife to keep her eyes on the road! lol
jharris2 said:No
Double-check the miles to make sure I have them right.
Yep.Jacobzky said:does this applies to a 2006 as well?
The light does not do any thing but light up every 5000 miles forcing you to do the reset procedure. It will never alert you to any problems.rx900 said:in the long run when the car gets older and older, we might appreciate that light when we find out possible problems before they get worse.:
