Reset tire air pressure warning light?
pook187
My mechanic says there's no reset mechanism and that he filled all 5 (including spare) tires to the proper pressure.
I suspect one of his assertions is untrue so I figured I'd ask you brainiacs.
I believe it resets with time. Ya know, an hour or two after you add air it should be good. Of course the only way to tell whats going on is....CHECK THEM YOURSELF!
That's weird!!
My 2007 Camry too has TPMS & the light came in handle a bunch of times, because we had a flat.
I fixed the flat & aired up the tire...the next time I drove, about half a block, the light went out by itself.
If you aired up all the tires when they were cold...then you should be fine.
Check EACH tire with a reliable pressure gauge and then drive. It may take a few miles, mine took about 5 miles at highway speeds.
It "should" reset after just a while.
Good Luck
