simple
Senior Member
I bought HID lights the day I brought home my 2015 almost a year ago. I tried installing them, and it was such a PITA with the tight quarters that I gave up and tried selling them. No bites with reasonable offers, so I tried 2 more times to install and again, gave up. Overall I was pretty satisfied with the OEM performance, but I still had these $150 lights hanging out in my garage, so I tried one last time and got it. This thread is meant to show where I mounted stuff which worked out pretty well for those like me who are a little daunted by the thought of stuffing wires everywhere.
I mounted the relay on the passenger side front side of the engine bay. I used a bolt through a stock hole.
The driver side is really cramped with the battery, so I mounted a majority of the kit on the passenger side to include the capacitor. For the mounting of the ballasts, I used some 3m heavy duty adhesive tape. I used 10lb, and it holds great. Although I did remove the orange bolt bracket to make it less bulky.
I mounted the capacitor with some adhesive tape as well, and grounded it to the screw just below it.
I routed the battery cable under the shelf in front of the radiator and used zip ties to keep it in place.
I mounted the driver side ballast on the metal shelf just infront of the battery facing straight up, and route the grounding cable to the bolt on the side of the battery.
Note the ballast just to the right of the battery in the pic above. You can also see the fuse that routes to the positive battery lead in the pic as well.
And for the clean look using the headlight cap, I used my rotary tool to drill a hole. If I ever go back, I'll probably just seal it with some duct tape on both sides.
I know this is pretty simple and probably overkill, but if this thread helps 1 person with the mounting, then thats cool with me. Like I said, I tried 3x and gave up before I finally got it down.
