Reverse Coupling in 90 4runner engine
LostinDartmouth
Hello:
I've put in a 1990 22RE engine into my 1988 4runner....engine runs great but need to re-hook the reverse lights. I can't seem to locate when the back-up lights coupling is near the engine block. there are a number of pigtails located near the Fuel injectors but I'm not sure which ones to plug into with the two wires coming from the transmission.... Anyone have some thoughts on this? Thanks Paul
The reverse light switch is located on the trans, so the harness connector should be hanging down in that area.
Thanks..I located the tranny ones, but was having trouble sourcing the engine bound ones....No problem now: I found the correct set of pigtails underneath the EFI block, through trial and error.
FYI to other posters: The pigtails are also grouped with the single plug that connects to the 4WD light sensor on the side of the transfer case....
Thanks for the help.
