reverse doesnt work only after going mudding
imboredeveryday
i have a 88 4runner 5spd and after i go thru alil bit of just liek mud puddles nothing to bad that i get stuck just to throw alil dirt on the truck i get it home and try to back it on to my drive way and put it in reverse and it stalls out even dumping the clutch it still stalls out so i pull it on the drive way let it sit for about 5 minutes and then back it up and then the reverse will work has anyone had that problem before and wat did they do to fix it also i have when im driving the hole truck will do a hick up and slams any ideas on that to any information to help me out will be awesome also where can i find a snorkel for it
imboredeveryday said:
i have a 88 4runner 5spd and after i go thru alil bit of just liek mud puddles nothing to bad that i get stuck just to throw alil dirt on the truck i get it home and try to back it on to my drive way and put it in reverse and it stalls out even dumping the clutch it still stalls out so i pull it on the drive way let it sit for about 5 minutes and then back it up and then the reverse will work has anyone had that problem before and wat did they do to fix it also i have when im driving the hole truck will do a hick up and slams any ideas on that to any information to help me out will beawesome also where can i find a snorkel for it
I dont have any advice for you, except try to write with proper spelling etc so we dont need an interpreter to understand what you are saying. I took the liberty of correcting your original post so you have a better chance of getting help.
I have a 88 4runner 5spd and recently I went mud bogging (nothing serious just for fun), and when i got it home and tried to back it into the driveway it would stall out, even dumping the clutch it still would still stall.So I drive it in forwards and let it sit for about 5 minutes and then try to back it up again and the reverse worked fine.
Has anyone had that problem before and what did they do to fix it?
Another problem I have is when im driving sometimes the whole truck will do a hick up and slams. Any ideas on that?
Any information to help me out will be awesome
One more thing, does anybody know where i can find a snorkel for it?
my 91 sometimes doesn't like goeing in reverse, but if i let the clutch all the way out and put it back in it usually lets me, but with a little groan. i also had a friend with your problem i think, he said he would just put it in second and go forward a bit and then it would go right in, i don't know if that works but its worth a try...
tuṣṭāva
