Reverse Light Mod?
Why do that?
I would run a separate circuit for a set of AUX rear lights.
You may want to think this out.
Has anyone been able to successfully mod their reverse light to turn on via switch in the cabin?
In my teens i did it on my old 79 Buick just for fun.
30 years later i got a set of Baja S1's at 2500 lumens that i wired properly with a switch and relay.
Fantastic for backing down trails and setting up camp.
I agree with others, what’s the point ? The reverse lights aren’t that bright. I would rather manually trigger a pair of 6” spot lights with a switch. Better yet, trigger the 6” spot lights in reverse.
But if you really want to create an anytime reverse light switch .. just tap the reverse light circuit. It’s on the drivers side footwell.
I just did something similar when I installed a victory 4x4 rear bumper which has 2x 3" led lights in it.
I tapped into reverse light on passenger side (from cargo area) using t-tap connector, relay and aob switch.
Standard relay connections:
85 to aob switch
86 ground
30 positive wire to led lights
87 accessory-on power (run with add a fuse to fuse block down passenger kick panels)
87a wire from reverse light
lights come on when put in reverse like normal, And, come on or when the switch is used in dash.
Check this out at Amazon
LED Light Push Button Switch with Connector Wire Blue Backlit Kit Compatible with Toyota Tundra Tacoma 4Runner-Rear Light Symbol Amazon.com: LED Light Push Button Switch with Connector Wire Blue Backlit Kit Compatible with Toyota Tundra Tacoma 4Runner-Rear Light Symbol: Automotive
Amazon.com: ONLINE LED STORE 6 Pack Bosch Style 5-Pin 12V Relay Kit [Interlocking Harness Socket Holder] [14 AWG Hot Wires] [SPDT] [30/40 Amp] 12 Volt Automotive Relays for Auto Fan Cars: Automotive
Qibaok 240 PCS T-Tap Wire Connectors Self-Stripping Quick Splice Electrical Terminals and Nylon Insulated Male Quick Disconnect Spade Terminals Kit: Amazon.com: Industrial & Scientific
Amazon.com: Uriveusa 12V Car Add-A-Circuit Fuse TAP Adapter Fuse Holder with 10A, 20A Fuse [Upgraded Fuses] - (2 Pack) (Mini Fuse): Automotive
85 to aob switch
86 ground
Very cool. Thanks for all the tips and replies! Yeah I'm just looking for a quick/dirty way to get some lights in the rear for when we go camping and stuff. I don't have any 3rd party roof racks to wire a whole Rear Light set and so I thought tapping into the existing reverse lights would be easier.
Also I thought it would be something cool to flash the idiot speed racer tailgaters..lol.
85 to aob switch
86 ground
I tried to send a PM to a member with a question, but I dont think I did it right, so here is the diagram...
seltzernator
