I have a set of Revtek top out spacers that I no longer need. They are $49 plus shipping new. This will provide 1/2" of additional lift on a 1995.5-2004 Tacoma and 3rd gen 4runners. It mounts on the top of the spring assembly, but you'll need the longer studs which will require you to dissasemble the spring assembly. The studs can be purchased from Cornfed and Wheelers for pretty cheap.
If you're already running cornfed spacers inside the spring pack, I've got the longer bolts you'll need to make it work with the cornfed spacers for an additional $5.
Chris
Chris
