Revtek 3/8" Top Out Spacers...$30 shipped!
ravencr
I have a set of Revtek top out spacers that I no longer need. They are $49 plus shipping new. This will provide 1/2" of additional lift on a 1995.5-2004 Tacoma and 3rd gen 4runners. It mounts on the top of the spring assembly, but you'll need the longer studs which will require you to dissasemble the spring assembly. The studs can be purchased from Cornfed and Wheelers for pretty cheap.
If you're already running cornfed spacers inside the spring pack, I've got the longer bolts you'll need to make it work with the cornfed spacers for an additional $5.
Chris
hey quick question for you... I already have a revteck lift in and want a little more lift in the front cuz I feel there is still a slight rake to the vehicle stance... You think I can just add it in addition to the one I already have and it be safe still? I already have the longer bolts cuz of the initial installation of the lift but I have a 2 inch difference between fron and back on mine
It's possible, but I would direct that question to Revtek directly and see what they say. I'm not familiar with the Revtek Spacers, buty I think that part of it compresses the spring height to achieve lift and it also lowers the spring all together if I'm not mistaken, so you may not be able to. I'm not totally sure, which is why I'd check with Revtek directly.
Chris
ughāḍiyā
