Rock Sliders!
4x Innovations Rock Sliders
come in a variety of lengths as well as custom lengths at no extra charge! Your slider can be built from 1.75x.120 HREW or 1.75x.120 DOM tubing, to fit your budget and wheeling style. Just cruising around in the woods, and muddy trails and want a little protection/step, go for the HREW. Romping in the boulders, dropping off ledges, and hammering on your rig, go for the DOM. If you are really hard core we'll even make them from heavy wall tubing, just pay for the additional materials cost. And of course as always these slider kits come with frame fish (scab) plates, and gussets to fully support your entire slider and truck frame the way it should be, and we don't charge any extra for the added parts!
Available sliders: Length / Yr / Model / Material / Price
  1. Use coupon code toyota4r5 for 5% off
  2. 60" 83-95 Std. Pick Up + 4 Runner HREW $178 - less T4R 5% discount -> $170
  3. 60" 83-95 Std. Pick Up + 4 Runner DOM $231 - less T4R 5% discount -> $220
  4. 66" 90-14 4 Runner HREW $183 - less T4R 5% discount -> $175
  5. 66" 90-14 4 Runner DOM $236 - less T4R 5% discount -> $225
  6. 68" 84-88 Excab Pick Up HREW $183 - less T4R 5% discount -> $175
  7. 68" 84-88 Excab Pick Up DOM $236 - less T4R 5% discount -> $225
  8. 80" 88-95 Excab Pick Up HREW $200 - less T4R 5% discount -> $190
  9. 80" 88-95 Excab Pick Up DOM $252 - less T4R 5% discount -> $240
  10. 60" 95-04 runner/std. Tacoma HREW $178 - less T4R 5% discount -> $170
  11. 60" 95-04 runner/std. Tacoma DOM $231 - less T4R 5% discount -> $220
  12. 80" 95-04 Excab Tacoma HREW $200 - less T4R 5% discount -> $190
  13. 80" 95-04 Excab Tacoma DOM $252 - less T4R 5% discount -> $240
  14. 05+ Regular Cab Tacoma HREW $184 - less T4R 5% discount -> $175
  15. 05+ Regular Cab Tacoma DOM $236 - less T4R 5% discount -> $225
  16. 05+ Access Cab Tacoma HREW $205 - less T4R 5% discount -> $195
  17. 05+ Access Cab Tacoma DOM $257 - less T4R 5% discount -> $245
  18. 05+ Dbl Cab Srt Bed Tacoma HREW $205 - less T4R 5% discount -> $195
  19. 05+ Dbl Cab Srt Bed Tacoma DOM $257 - less T4R 5% discount -> $245
  20. 05+ Dbl Cab Srt Bed Tacoma BOLT ON DOM $450 - less T4R 5% discount -> $428
  21. 05+ Dbl Cab Long Bed Tacoma DOM $288 - less T4R 5% discount -> $275
  22. 95-97 FJ80 and LX450 BOLT ON DOM $578 - less T4R 5% discount -> $550
  23. NEW Upgrade any DOM slider set to a 2 inch square main tube for just $72!
Contact us via phone or email anytime.
You may be looking at the list and asking what the difference between the HREW tubing and DOM tubing is. Here's some info for you to consider.
The HREW stands for Hot Rolled Electric Welded. This tube starts as a strip of flat plate that is heated, rolled, and welded into a tube shape. The shape of the tube is determined by the rollers that roll it and no second operations are performed. It is also typically rolled from a softer steel.
The DOM stands for Drawn over Mandrel. First off, DOM IS still welded seam tubing, just because you can't see the weld seam doesn't mean it isn't there. The only tube that is seamless is actually called Seamless Tubing. Seamless is VERY expensive and mostly only stainless steel or large tube sizes. Don't let others fool you about that. DOM starts its life as either HREW or CREW (Cold Rolled), depending on who is rolling it, that has been rolled oversize. That oversize tube is then sent through a die and mandrel that shape the tube into its final size. This process is done cold which work hardens the steel, making it significantly stronger. The process of resizing and cold working the tube gives a more uniform shape and size and smoothes the weld seam. The DOM we use is also made from a higher grade steel that is stronger to start with. Over all the DOM is going to be around 30% stronger than the HREW tube.
DOM is significantly more dent resistant and is strongly recommended as the material of choice for heavier trucks such as the Tacoma. It is also strongly recommended as the material of choice for any roll cage. The drawback is that it has a higher cost than the HREW tubing.
As always we can build any style of slider you'd like also! We've built lots of custom sliders for very happy customers. Anything from an FJ40, FJ80, and even a Blazer are running custom sliders! We are here to build parts for YOUR truck, not ours, and we want you to love what you get! If you've got an idea for a different design, send it over. You will love our quality and price!
Order placed! :bounce:
What is the width of these? Either from outer edges or the space between the tubes or center to center. About to pull the trigger but need that small detail.
Hey how are they working out for you? Any fitment issues? Did you go with hrew tubing?
Questions!
I love them! No issues at all. Yes, I went with hrew. I got advice on prepping and painting too and it's held up exceptionally well and they clean up nicely. Happy with this purchases by far and for the cost, you can't beat it.
Thanks again Terri! [MENTION=76968]traxman25[/MENTION] I'll be in touch
What are you all using for paint? I went with some Rustoleum bumper paint and it didn't work worth a damn. Any ideas? I love my sliders but I want to keep the rust away and keep them looking decent.
Questions!
i hate them, j/k i dont think there will be fittment issues since you have to wled them together yourself. if there were fittment issues that would be self inflicted :P
prepping the sliders is key to a long lasting durable coating.
Thanks for posting your pictures, that helped me make up my mind and order from 4xinnovations. How did you paint yours? I'm thinking of doing 3 coats of rustoleum primer, 2-3 coats of enamel, with a bedliner spray on top.
Here is my recipe for success:
-buy a hi temp heat gun, spend the $20 at harbor freight for one. trust me.
-Rustoleum Rust Reformer as a BASE coat
-Rustoleum Hi Temp paint
-Rustoleum bed liner spray
i used two cans of each except the bed spray, i had left over from painting my roof rack. only need a little of that for texture so kiddies will not slip off
one hand spray the rust primer inhibitor.
one hand hold the heat gun at high.
you want to spray and then quickly dry it with the heat gun. this will make it bond and dry ASAP. waiting for paint to dry is like poking myself in the eye, fun lol.
repeat until done.
note: light coats, no need to layer it on since you are really really speeding up the drying process by using a heat gun :) i noticed i would lay it on thick and it would run because i was impatient and hate waiting for it to dry. then try to move it when it was wet.
hi temp paint next. same process. its high temp so you will see the paint dry!
then i did a few coats of bed liner on the top for grip. you can sprinkle sand on a thick wet coat of hi temp also. but i had bed liner spray so why not. caution bed liner spray doesnt like to be heated as hot as the other two paints. bed liner will bubble when hot LOL.
here's the paints
20140626_123800_zps0brwuij0.jpg~original
here's a shot of my sliders at the front passenger side behind the front right wheel. this is where all the rocks and road debris will hit it. been almost one month and 2000 miles, no off roading yet though. idea is to show you how durable this paint is. i didnt apply bed liner to that area either. thats just dirt, no pitting, peeling, rusting etc
20140626_123824_zpsbntw0cx1.jpg~original
pictures on my 4r
side views and mounting/welding
Thanks for the help! I'm gonna spend a lot of time priming and painting these, I don't want to have to redo them every year. And luckily, I just picked up a heat gun
Thanks for the help [MENTION=93434]gshadow325[/MENTION] and [MENTION=72408]Mytoy4[/MENTION] ! Got these in this weekend and put on a coat of rustoleum. Will finish that up and add bedliner next weekend when it isn't 100% humidity.
And after learning to weld as these went on yesterday, I can definately appreciate the quality of the welds in these sliders. [MENTION=76968]traxman25[/MENTION], these rock.
With the standard 6" legs, how well do these sliders perform as protection against door dings in parking lots? (2014 Runner)
Question for owners: Do these interfere with getting in/out of the truck?
I had a set of sliders on a previous truck and they frustrated me with having climb in/out OVER them/always brushing my leg against them (not good in work clothes). However, those sliders were angled up, not flat like these. If these don't get in the way, then that's good news.
You can weld them at any angle you want or cut the arms shorter to have it stick out less. It's basically all up to you and how you want them.
10489844_10152515571148346_5150558306060428629_n.jpg~original
FB_IMG_1405901281958.jpg~original
Great product!
Have been searching and couldn't find a finite answer, but what length and
AndiGarage
