Rokblokz Mudflaps, good cold day project.
Can someone with the mud flaps take actual size measurements?
Don't really want longer mud flaps but I do need some a little wider.
I just installed these as well last month. It's tough to tell in this photo, but the regulars work well with 285s. There's a big difference in terms of spray on the side. I'm not sure there's a difference compared to the OEMs in terms of hatch spray.
They do hang lower than the OEMs enough that I'll probably take them off when it's time to hit the trails in the summer.
Also - zero rub with the 285s, which is what drew me to them in the first place (OEM fronts were removed with the lift/new wheels).
Any spacers with your 285s? Or what offset are you running? Trying to decide between the reg or XL myself. Im running stock Off Road wheels, 285s with 1.25" spidertrax.
What material are these made of? Is it a hard plastic like OEM, flexible rubber like old school mud flaps, or somewhere in between?
They are not flexible rubber. It’s about the same stiffness as the stock.... maybe a little stronger material. I installed them and really like them. Much better coverage vs the factory flaps and more clearance for the front. Haughty recommended.
This appears to be about the best source of info for Rockblokz mudflaps on the 5th gen’s but curious if anyone subscribed has any more info about fitment or long term use ?
Anyone run into
Problems with them ?
Seems the thread went pretty quiet.
I’m looking to go bigger rubber and want to keep the front mudflap protection and possibly improve on it.
Anyone run into
if you want a flexible option (rokblokz are stiff plastic), rally amor might be better - 2012-20 Toyota 4Runner, Rally Armor
2001ATL
