Roof pillar trim removal.
pipefitter
I did a search under quick links but couldn't find it. I want to remove the trim with the gold "4Runner" emblem in it from my '87. I have the sliding windows out of the truck and am prepping for paint, and thought I would freshen up the trim piece. It feels like clips hold the thing in place, but I don't want to force something.
Not exactly positive what emblem you mean, but the emblems on my truck seem to be held on with foam tape.
Saw behind it with a guitar string, I prefer nothing but Ernie Ball Super Slinky medium weight A string ( cos they sound like shet on my guitar so I dont miss them), or maybe some fishing line or even a big wide flat razor.
If there really are some pins, same thing works, or a thin flexible spatula and go slooooooooooow
I mean the black trim just behind the doors. It has a "4Runner" emblem imbedded in it. The trim has to come off in order to remove the emblem.
yep ... there is a procedure . but you cant save the clips .
here is the procedure :
first - push forward on the lower portion of the sail panel , this will release the lowest clip
second - push up , and this will release the upper 2 clips
third - push down to release the 2 middle clips .
I have never been successful at remounting the panel , or removing the clips to reinstall them onto the panel .. We offer a clip kit (set of 10) for $23.00 + parcel post http://www.toyotafiberglass.com
hope that helps
I will try it. I removed the sliding windows and trim. (Unfortunately, the weatherstrip is no longer available!). I figured since I've gone that far, I would attempt to pull the sail panels, and clean up, or replace the emblem. Thanks for the link!
Deka
