Roof rack Mounting Options
CarmMontana
Hey Guys
I am building a full length roof rack and wanted to know what you all have come up with for mounting. I noticed Whitson has used the factory mount but not the crossbars and I also saw a few that went straight to the body. What is best in your opinion? Thanks Guys
Any pics would be sweet.
This is a good question. I'd like to see a rack that bolted simply to the existing holes in the roof (maybe 4 or 6 locations, out of 10 existing holes), doing away with the side rails. To me, this keeps things clean and uncluttered, and simplifies the whole set up. A siliconed machine screw could be threaded into any unused holes.
I made custom mounts for my half length Rola Vortex rack. The mounts are 6061 T6 aluminum. They use the existing factory threaded M6 holes. I will be refining them a bit. I'm going to try and add aluminum side bars running from mount to mount on either side of the runner.
See pics below
e409d861.jpg~original
61ca2d61.jpg~original
I like the idea of going straight to the body in the gutter portion. It would make a super clean and close install. Anybody done that before.
I like the way you installed your rack but I'd even like to go lower... Thanks for the pics
Thule or Yakima
You could also adapt your rack to use thule or yakima rack perches that hook into the existing OE rack.
A neighbor of mine made this work on his 98.
You can mount straight to the roof very easily like qyota mentioned. A member (Wastedaccount) purchased a rack from me and mounted it this way, even though i set them up for mounting onto the stock rails. Do keep in mind the roof's arch wont let you get too low, the rack in my signature sits about 3/16" off the roof at its lowest center point.
I designed a roof rack that will screw directly to the 10 roof holes. I had to do it this way to keep it low, so the truck will still fit into my garage. I will be building it later this summer/fall.
H.Sikina
