Roof rola basket with custom mounts
Bumping this to add my setup since this thread inspired it. Curt rack with a single extension mounted using Jaketino's method. My aluminium mounts are slightly shorter in height and the U-bolts that came the Curt rack were too long to work so I used some steel strap and bolts instead. The rack slightly hangs over the moonroof but it still opens with no issues.
Got pictures?
I took the original mounts that came with the rack, cut them in 1/2, & the welded them to the bottom of the rack itself...
I achieved a super low profile mounting system that uses the factory roof rail mounts with the twist lock things...
I did a similar thing to mount my Surco rack as well!!
sits very low. And I can get in the garage!!
Just seen this thread, we did something a little different, but not too difficult. Welded tabs to the basket, used 1"x1" square tubing for the mount, and bolted the tubing to factory mounts and carrier to tubing. If that makes sense. Bryan
Thanks for the positive response.
Yes I agree the original roof rack is a little too weak, considering part of the cross bar is made of plastic.
Anyways here is the items needed to build the custom mounts.
You need:
Two L shaped metal measuring 2 1/4 X 1 1/2 and 1 1/2 X 1 1/2. They are both 4 feet long.<br>
<img src="http://i24.photobucket.com/albums/c15/japrsx/DSC09651.jpg">
<br>
Then you would need bolts that would fit into the holes of the metal pieces.
Cut the metal pieces into 1 feet sections to provide good support.<br>
<img src="http://i24.photobucket.com/albums/c15/japrsx/DSC00656-1.jpg">
<br>
To hold the mounts to the roof rail I went to the junk yard and fround my self a 96-02 4Runner and took the metal slides with the bolt hole so I can add more mounting points to the roof rail. I added 5 of those metal slides to each side. I used bolts that holds the roof rail to the roof, alone with washers to bolt the mounts for security reasons. <br>
<img src="http://i24.photobucket.com/albums/c15/japrsx/DSC09646.jpg">
<br>
As you can see on the picture above I reused the long U bolt provided by Rola and a few more U bolts that I brought to secure the basket to the mounts.
<br>
After this simple steps you should have pretty good mounts to hold your basket. So far weight tested to 250lbs stationary.
Is there a particular reason you made the longer with added U-bolt instead of just using the bolts that came with it? Added Strength?
So I finally installed the lights on the basket lolz
Now I have a total of 20 Aux lights on my 4Runner:
6X HID retrofitted Hella 500
2X Hella 550
8X LED fog light perimeter lighting on the basket
4X LED fog light undercar lighting
How did you mount these lights to the basket? How did you run your wires? They look great.
Cpn2mss
