Rotiform SIXOR with stock tires and suspension.
jeroweezy
any input with this setup? would i run into any issues with running Rotiform SIXOR wheels. they are 17x9 +1. i would be running them on ko2 265/70/17 tires with stock sr5 suspension? i have seen multiple setups with these but they are all lifted and running 285 tires. any pics of simliar setups just to give me an idea would be great. thanks
That 5" backspace is probably going to put you very close to if not in contact with the upper control arm. The factory Trail/Off Road wheel has 4.750" BS and that is the deepest of the 3 available Factory 4R wheels. Sorry but that's the best I can offer. You might try running your hand behind the tire and see how much you can fit between the tire and UCA now. IIRC the SR5 factory wheel has 4.5" of backspace.
Of course they do list the 4Runner at the website, so what do I know?
http://www.rotiform.com/iconfigurat...age=1&color=10972&wheel=8540&wheelimage=33195
I'm running 285/70/17 with the SIX OR on stock ORP suspension, not sure if that helps you with running it with stock tires. Don't have issues with it rubbing on the UCA
Sent from my Pixel 2 using Tapatalk
i think our UCA are all in the same position in regards to how close it is on the wheel regarding of suspension(i could be wrong) plus if you dont have any problems on 285 tires i should be okay with 265. will have to do more research..if all fails..TRD sema..just dont like the look of the stock wheels
that is good to know. i have emailed rotiform to get their take on it.
Jhunt
