I have a 2008 4Runner Sport V6 with 125k miles. From Central California. In winter, I go snowboarding. I also spend a lot of time at the beach. In spring, I do light offroading in the so-cal desert, as well as in Sierras. Occasionally, I'll decide to go for a drive and end up places like Colorado, Utah, Idaho, Washington, and Oregon.
I need to do my brakes too and I'm confused on what parts to buy. I need part numbers. can you guys help me out? I've never done brakes before but I am mechanically inclined so I have no problem doing it myself. But I'm debating what to buy.
Assuming I stick with stuff made for 4th gen...
1. If I go with Akebono brake pads, which do I buy?
ACT976 ProACT Ultra-Premium Ceramic Brake Pad Set - $49
https://www.amazon.com/dp/B000C1LLPA/
or
ACT606 ProACT Ultra-Premium Ceramic Brake Pad Set - $44
https://www.amazon.com/dp/B000EQ0O7O/
2. If I go with Centric rotors which do I buy? Their website states the following.
Premium Rotor - 319mm Front Disc; Front Caliper Casting# 13WG - Front ($47 each)
Part: 120.44129 (2 per vehicle)
https://www.amazon.com/dp/B000BZXR0Y/
Premium Rotor - 338mm Front Disc; Front Caliper Casting# 13WH - Front ($50 each)
Part: 120.44127 (2 per vehicle)
https://www.amazon.com/dp/B000BZZPRC/
Premium Rotor - Rear ($41 each)
Part: 120.44128
https://www.amazon.com/dp/B000BZZPRM/
3. If I go with Brembo rotors, which do I buy?
Brembo 25676 Rear Disc Brake Rotor
https://www.amazon.com/dp/B000E5T5EI/
4. Are these the right Anti-rattle w/ hole pins?
Carlson Quality Brake Parts 14023 Guide Pin Kit
https://www.amazon.com/dp/B000BZYT9W/
5. Is this the right kit for pins?
Raybestos H15506A Professional Grade Disc Brake Caliper Hardware Kit
https://www.amazon.com/dp/B000R4A3BA/
6. Should I replace the calipers?
Someone mentioned upgrading to 5th gen brakes. This is possible? If so, what brake pads and stuff do I need to buy?
