Rpm ???
91 stock with 4.56? Really? That's odd my 92 had 4.30s....u scored lol...or the PO swapped out for stock 4.56s
Many runners (and pickups) came with 4.56, usually to help with the auto tranny/ factory 31s/ and or tow package. Some even had 4.88s.
No I think u still got 4.10s....if u wanna check without pulling the diff, Jack the truck up chalk the drive shaft and tire, make 1 full rotation with the tires and count how many times your drive shaft spins wont be super accurate but it'll give u an idea
How many turns should the driveline spin in that one rotation that would signify 4.10?
4.1 :naughty:
Yes 4 full rotations and a little past the center mark .10
Not if you have an open diff. If you are just spinning one tire, you need to go two full rotations of the tire. If you're spinning both tires (rolling the truck), one rotation is correct.
Oh I see, and I do have the open diffs.
Ok, about higher gearing.
Gearratiosanddiffs
This chart says I should change to 4.56 for 32x11.5's .. would I really see any huge benefits obtained by getting this done someday? gas mileage? extra feeling of power, etc.
I also noticed this:
Toyota sometimes mistakenly coded trucks with 4 pinion
diffs with a "2" code. To verify if yours is a 2 or 4 pinion
diff, count the number of fins on each side of the diff. A 4
pinion diff will have 4 fins on each side. A 2 pinion will
have 3 fins on each side.
What are the "fins"?
But if I really do have 4.10, how important is it to get 4.56?
(I'll always be running 32x11.5's)
The v6 should be fine for 32s, if then feel too slow after you can always change them out.
Picture of "fins"
From this page Erik's Toyota Differential info
hmm .. doesn't feel slow at all. I need to make sure I still have the stock 4.10 or something else..
Thanks for the pics. When I get my 4Runner back from my body man, I'll look at those fins to see what my pinion deal really is.
