RPMs at highway speeds?
gloch
Member
What are your RPMs at highway speeds? My 03 V8 has been making an odd sound recently at 70mph+ almost like it needs to shift, but the RPMs are at around 2k. Is this normal for this speed?
Around 2k, maybe slightly higher but I have the 5sp transmission.
Maybe you need a transmission fluid exchange?
I just had my transmission fluid changed at 200k. I suspect it's probably a good idea to do it before then, though. No off-roading, no towing, just a highway warrior.
This is what I am wondering. How often should the tranny oil be changed?
60k if towing or harsh conditions...100k otherwise should be fine. People have gone longer, however. Toyota originally said “lifetime fluid” but I don’t buy it.
I just recently did mine at ~130k but I had no prior issues. Under $60 for 12 quarts of Valvoline MaxLife and I did it in my driveway.
03 v8 here
Mine is about the same
Sent from my SM-G950U using Tapatalk
Agreed, that sounds about normal.
I wonder if your torque converter isn't going into lockup mode and that's the "need to shift" feeling you're describing.
I'm pretty sure if the torque converter isn't locking up the RPMs would be higher than normal, but I could be wrong, at the very least the RPMS would fluctuate at a constant speed if the lockup clutch friction plates are slipping.
I also think it would throw a code.
Usually keep it around 2k RPM on the highway, v8 5spd. I find hills to be annoying and it constantly shifts into 4th and wont get into 5th for longer than I want it to. In cruise control it has to be flat, whenever the cruise control tries to pick up speed, it drops down 4th and gives it full beans!
Jhunt
