Running board courtesy lights cut
agboise
Hi guys!
I just bought my 4Runner (2003 Limited 4x4), and when I took it to the mechanic to have it looked over he said someone had cut the wires to the courtesy lights on the running boards on both sides.
I was going to try and get under there tomorrow and see if I couldn't reconnect them, but first I was wondering if anyone had any idea why the previous owners would have cut the wires? Has anyone had issues with them maybe staying on and draining the battery or anything?
Thanks guys!
Strange that someone would cut the wires. Did they cut them before or after the connector? Only problem I've had with mine was the splice inside the RB that I had to repair. Its no biggie to drop them and take them apart for the repair. Throw some LED's on while your at it :thumb3:
They probably had taken the running boards off while they had it and put them back on before they sold it.
I don't actually know, because I don't actually know what that means. I took a few pictures of where it was cut. This is on the passenger side, toward the center of the running board. The connection toward the front seems to be fine. I imagine the driver's side looks the same. (Please forgive how disgustingly dirty it is. I feel like I've adopted an abused pet and I'm nursing it back to health. ): Someone didn't love it like it deserved.)
Wow, people do weird stuff. From the picture it appears that the connector is still...well...connected. Maybe they couldn't or didn't know how to get it apart when they dropped the running boards. Might be worth your time to get a couple new connectors from a dealer and rewire that section instead of dealing with the old ones.
Sounds good. Thanks!
I only thought of it because I want to take mine off so i can repaint one of them. I had looked under it and was thinking it would be so much easier to just cut them off.....not that I am going to. Hopefully yours will be a simple fix. I love having the lights on mine. They really help with the LEDs in them
Hello,
I would like to resurrect this thread as it is the same issue that I am having.
OP, what was the resolution to the issue you had with the connector for the running boards? If you bought and installed new connectors, where did you purchase them from?
Hello,
I sold it very shortly after this. I never did find a solution. ):
Good luck!
Hello,
Would these help?
Fox, if the OP doesn't want those, I'll take 'em. All my connectors and wires have corroded out.
