Running board removal?
WTG13
So I've done a little searching without much luck... I've got a 98 SR5 with the factory flares / running boards. Does anyone have a pic of what this set up would look like without the running boards? Anything I would need to do to the stock flares to make it look "clean"?
Here is mine. If you look at my build, you will see more pictures of it. I have added a temporary brush guard and tube rear bumper but you can get the point.
Thanks for the pic, it looks better for sure!
I have a bit different set up on my truck though... My running boards mate up differently with my front flare (goes up a bit higher) and I'm concerned that just taking off the step will make the front flare end "abruptly"
Here's what I did...I took the running boards off and cut the plastic piece off the running board and screwed it in place to fill in the gap your talking about. I just used some thin metal to support the mud flap. I guess OEM mudflaps are crazy expensive and hard to find. This was free and it works great in my opinion.
If you haven't already, post some pictures of your 4Runner in the Stellar Blue Pearl Thread (Found Here)
delislerebecca
