Running Only One Rear Coil Spring Spacer?
robot808
I bought my 98 Limited this spring, and it had a little bit of a sag in the rear end. It also leaned slightly to the right, but today I was just going to worry about taking care of the rear.
I bought a set of 1.5" Daystar spacers (as much as I'd love to, I won't realistically be getting off road much), and installed one on the passenger side.
I was turning the 4Runner around to install the driver's side, when I realized all four corners look even now. Measurements from the center of the hub to the fender confirmed 21.25" all the way around.
So, am I done? Or would it be unsafe to run one spacer for some reason?
Thanks for any help!
Bob
Elmhurst, IL
1998 4Runner Limited
I'd be scratching my head as to why adding an 1 1/2" on the back RIGHT would level everything out. With the driver and fuel tank both on the left side, that's where all the weight is. I would do a detailed inspection of the whole rear end to see if there's something bent\broke that would cause the right to sag that much. Stock springs or aftermarket? I wonder if previous owner had the springs swapped. Some spring setups have two different sizes to take into account the weight of the driver and the fuel tank.
To start, I would pull both rear springs and line them up side by side, trying to find out why that 1.5 spacer levels out the rig.
That way I could rule the springs out as a problem if they measure closely.
delislerebecca
