Rust and rotting frame
Great news; you are in fact dreaming! As a matter of fact, you may even be on recreational substances!
Oh well! Had an old GM guy who talked with some mechanic said it might be in the works!
When the story has a background like that, it's always wrong. There's never any insider secrets going around in the Toyota dealer quick lube department.
I fixed an 18" long section of frame on my 99. Took me about 20 hours to design a 1 piece 3 sided section that would go over the rear axle hump and all the way up to the rear crossmember. Then I slid the 3 sided box over the top of the frame to start making the box and cut the 4th side for the bottom. Welded it all together and into the frame and it's good as new.
OP there will never be a frame recall for these things you either scrap your truck, get someone to patch the frame, or get a rust free frame and swap everything. Take your pick none of them are fun.
Found a nice frame for $350. Couldn't believe it. Already installed.
....and it only took you 19 months!!!
J/K. Good work. DIY or did you pay? If paid, I'm curious what that cost....
You can see what I did in my sig.
I had an estimate of $2800. + or - mostly +. $900 extra. Still very happy. While it was all apart I put some Bilstein 5100's. And new front coils! No worries any more.
bobdjr41
