Rust/corrosion
Winston81
My 2002 4Runner is originally from Pennsylvania, which i should have paid more attention to the amount of rust beneath it, but i was so stoked on it... Anyway, maybe a dumb question but what is the best way to clean it up and protect it from worse damage? Thanks- Jon
Talk to the professionals. Take it to a shop who does undercoating. If you wanna do-it-yourself, that's a lotta work and time to include the proper materials you need to buy.
thanks.. will check into it!
ok, dont waste your time at at shop unless the chassis has holes in it. I doubt you have more rust then me and mine is 5 years older and in the heavyest part of the salt belt (NY-CT), and had no protection. Mine is regular surface rust which can be solved with a little work on your part. I would suggest you pressure wash the underside of the runner, then once you get it as clean as you can from pressure washing, go get some POR-15 and a paint brush and begin to coat the steel parts (Chassis, the back sides of the Bumpers, Skidplates,) until your satified with the coating. POR-15 will absorb surface rust and prevent them from rusting again. It wont be that bad to apply the POR-15 either, although mindless and time consuming it is way less expensive and it is no different than painting except that it doesnt matter how bad it looks.
Hope this helps.
P.S. i like the color of your 4runner.
Phosphoric Acid will easily get rid of surface rust and allow you to paint the surface. It is fairly cheap and can be found at most hardware stores (~$15/gal).
someone else told me to pressure wash it and just get a can of undercoat spray and coat it.. After being under there though I reallize it's not as bad as i thought it was... thanks for the help though.
Spraying undercoating over it is just putting a band-aid over it! Undercoating will NOT stop rust, it will keep speading and get worse even under the undercoating! You need to use a rust neutalizer like por-15, that's you best and easiest solution if really want to take care of it!
:iagree: POR-15, the best thing out there to combat rust.
Wirebrush, then POR-15 paint.
I need to do this to mine in the spring. I didn't get to it early enough so now I'm just painting on some thick bar & chain oil to protect the rust spots over the salty winter.
