Saker’s Ebony Build
February 18, 2021
Updated Raptor Light Switch from AOB
From this:
pn8sM4zgj
To this:
pnNdzePzj
February 19, 2021
Toyota Aluminum Oil Filter Cap Installed
Toyota Part # 15620-31060
pnsh91aLj
I haven't seen it listed, so...did you replace the dash tweeters on the '21 with the Subaru tweeters?
You know, I ordered a set, installed them and pulled the right out and sent them back!
I didn’t like the way they sounded. They were too tinny.
They are strictly tweets, no midrange at all!
There has to be a better option than those for that location!
Plenty of alternative solutions in this thread. Some really liked the Subaru tweeters, others were not impressed. Still others had suggestions and install instructions for better speakers for half the price (with one version being considerably more @ $229):
Kicker Subaru Tweeter Upgrade for 4runner?
May look into this, I have 1 more switch location open on the dash!
Thx for helping me spend money. :hiding:
Then wire the meso puddles to your reverse trigger. It lets others know your backing up. Also provides additional light when backing up.
Oh that’s a good idea. I’ll have to look that up.
Thanks for the suggestion, but not doing that.
I’ve got Rigid’s that provide more than enough back up light! It’s like the Sun shining when it goes into reverse! :D
[MENTION=628603]WakeTime[/MENTION],
These photos may help you a little more.
In the first photo, notice at the end of the crude arrow, there is the small buss bar under the OEM fuse terminal to make the connection to the battery terminal for the cable to the auxiliary circuit.
This way all power to the auxiliary circuit is bypassing those fuses.
Hope these help.
pnKReINSj
pnB7cPk0j
Those two fuses, is that something new for 2021 models?
I presume the 250A is from the alternator? And the 70A is for supplying the vehicle’s loads?
July 29, 2021
Removed my Vinyl Wrapped Front & Rear Valances & installed Black Ones
Installed my [MENTION=602811]ctnewman[/MENTION] Rear Tire Carrier
Man this thing is Awesome
pmNJ0QRQj
pmAgITRMj
pnGtHaWUj
po7f15EZj
pmNJ0QRQj
pmAgITRMj
pnGtHaWUj
po7f15EZj
Wow awesome! So does that just attach to the existing trailer hitch and then still leave a spot to use for towing?
seltzernator
