Satoshi Grill Mod - 5th Gen
The stand-offs (posts) that are on the backside of the emblem prevented correct alignment with my grille's mesh spacing. I cut the posts down and left the base of the post, then I drilled holes in the base to allow a very small stainless zip tie to secure emblem to grille. This was the only way I could center properly. The emblem stands off the grill about .25" which, to me, looks intentional.
It's lovebug season in Florida and we've washed the truck damn near every 3rd day; so far the emblem hasn't budged.
Thanks for the response. I had read the entire thread before, but somehow I missed folks talking about cotter pins and double-sided adhesives. So after I :rtfm:, I proceeded with the install.
Finished the project in just under five hours, with just one break for lunch. Before I figured out the "trick" to pulling off the top bumper *, I managed to cut the *^&^ out of my hands. If I get inspired I'll take a picture of them.
Anyway, here's a crappy iPhone shot of the finished project:
Grille.jpg~original
When I get the beast washed I'll take real pictures with a real camera.
* I have a Trail Edition. I read and reread Toystory's guide to removing the bumper (awesome write-up, by the way) and thought I knew how to tackle the job. Only problem was, in my vehicle, there are two vertical plastic "covers" whose function seems to be to protect the headlight area from the grille. Nothing I could read talked about these covers, or how to go around them, or even how to remove them, so I tried wedging my hands inside them. That's how I cut the crap out of my hands. I even tried accessing the infamous "green tabs" from Toystory's write-up from the ground, but no dice. I was beginning to get frustrated and had almost given up on the whole project when I thought to myself: Self, Toyota techs have to be able to access these parts, you're probably making this way harder on yourself. And with that thinking, I put my left hand on the plastic beneath the passenger side headlight and pushed in, and with my right hand I simply pulled the bumper toward me. Worked like a charm.
In fact, it worked so well I was afraid that I had broken a tab from my earlier attempts. But when I finished the grille and snapped the bumper back into place, everything snapped in nice and tight and there was no movement at all, so obviously I hadn't broken anything.
Once again, thanks to everyone who has forged these roads before us. Makes it soooo much easier for the ones to follow, at least for me.
I think those "covers" are to control the airflow...they keep everything flowing directly through the radiator, instead of going around the sides.
You are right about them being a PITA!
When I did mine, I just bent them over sideways a bit until I got the grill off. Then when I put the grill back on I had to make sure they were lined up again.
Has anyone blacked out the TOYOTA emblem when doing this mod? I didn't notice anything in any of these posts so far. This is most likely the next mod I am going to do but would want to black it out.
Is the emblem painted plastic in the middle of the letters?
Would sanding it and using a plastic bonding paint like doing the stock emblems work?
Probably gonna give it a try...
Does anyone know where to get the OEM style honeycomb grille?
I really dislike the grillcraft mesh..
Well, I compared the lower grille to the upper, and it isn't the same depth, so hacking it into the upper grille isn't even an option (I've seen this done on VW forums before). I, too, would prefer a really similar to OEM, but my searching around the internet showed nothing similar.
Kingpin - he's talking about a blank grille... one without the badge and "wings".
Maybe it's just the angle of the picture, but it looks like the emblem is off center. Too far to the right.
The mod looks good, though.
I have to run a front license plate, so that screws up the look of the front end already. What are you guys that run front plates doing? Top and bottom grill or just the top?
yeah, I pulled the lower one out today to play with it.. no dice.
i've done that in my tC before, too.
looking for a matching pattern on the web now..
Kingpin, how was the mod to the lower grill area? as easy/difficult as the upper grill? Also, is that the custom mesh from "custom grills" or the GC kit?
I am about to order the parts for this mod and def want to do the lower at the same time in order to match everything up.
Looks great by the way!
Pattern
I like the pattern used by T4R.ORG, but in plastic, not metal. Look at the top of each page of forum. Too bad can't find it.
OK, so I got frustrated searching for something I read....somewhere on the site...
I saw some posts from someone who had removed the white from inside the "TOYOTA" emblem most are using for the grill mod. Does anyone know who that was and where it was??? I want to get in touch with some specific questions.
I apologize if it was a simple search for some of you, I couldn't find it.
So what's the verdict on the best place to buy the grill and then the emblem? I want to order today! :)
Need some help. Need a P/N for the Toyota emblem! The one I thought I was going to use is discontinued, please help! I have the Grillcraft stuff sitting in the corner....
charlesz
