CBR_GUY_IA
T-SB-0053-08
May 8, 2008
Alignment Pin Installation during Transmission/Transaxle Assembly Installation
Service Category
Drivetrain
Section
Automatic Transmission/Transaxle
Market
USA
Applicability
Introduction
The purpose of this TSB is to provide information regarding the installation of alignment pins during transmission/transaxle assembly installation. Missing alignment pins may result in incorrect alignment and failure of the transmission/transaxle assembly. Use the information below when installing a transmission/transaxle assembly.
Parts Information
Warranty Information
Repair Procedure
1. Inspect the rear side of the engine block assembly for 2 alignment pins.
^ If there are less than 2 alignment pins present one may have been removed with the transmission/transaxle assembly. Check the removed assembly for the missing alignment pins. Go to step 2.
^ If there are 2 alignment pins present the transmissionltransaxle assembly may be installed following the applicable Repair Manual procedure.
NOTE :A missing alignment pin may result in failure of the transmissionltransaxle assembly.
2. Install the missing alignment pin(s).
^ Refer to the applicable Repair Manual procedure for location of the cylinder block rear side alignment pins.
NOTE In the Repair Manual, the alignment pin is referred to as a "straight pin."
May 8, 2008
Service Category
Drivetrain
Section
Market
USA
Applicability
Introduction
Parts Information
Repair Procedure
