ScanGauge II owners - Intake Air temps
They make throttle body spacers too, and they do absolutely nothing on a direct injected motor. (which our 3.4L is)
Our motors do not have direct injection, they have sequential MPFI. Direct injection is relatively new for mass production vehicles and requires very high pressure fuel pump and injectors to meet the demands of direct injection fuel delivery. If our motors had direct injection they would be making a lot more power than the stock horsepower.
It works in the same manner as a 40 degree ice tray freezing faster than a 100 degree ice tray, all other things equal. It just take less energy to make the matter conversion.
Sorry, but this is absolutely not true. Rationally it makes sense, but scientifically it is not true. The hot water will freeze faster than the cold water.
It does not take energy to lose heat. You are losing energy to a colder, less energetic state (let's assume you put your boiling water and room temperature water outside in Canada in the winter).
Anyway, it's called the Mpemba effect and it is, as of now, unexplained.
I don't want to jumble this thread up, but I think this is interesting and thought I'd share.
Back on topic....
Do any of these OBDII scanguage type tools store data for you to download to a laptop and excel type file?
we can discuss it more in a pm if youd like, but the Mpemba effect only occurs sometimes and does not seem to obey the laws of thermodynamics. Scientists are yet to explain exactly what or how it is happening.
We'll stick with the non Mpemba effect, which occurs most of the time. I was referring to the energy necessary to remove the heat from the freezer with the ice trays. Of course if you stuck it outside in zub zero temperatures it wouldnt cost anything.
Correct. It does not exactly fit the laws of thermodynamics and it is unexplained.
Responding to PM...
Gerdo:
These should work for you.
Air to Fuel (lambda)
TXD: 07E02144
RXF: 04614544
RXD: 2808
MTH: 006400800000
NAM: AFL
Air to Fuel (True Ratio)
TXD: 07E02144
RXF: 04614544
RXD: 2808
MTH: 05BE00800000
NAM: A/F
I think I have probably tried this set but I'll try it again.
Ill add my 2 cents to the list:
deck plate, airaid intake, trueflow filter, 72 degrees outside got a 75.2 degrees on the intake temp gauge.
seems pretty good to me. thats idle on the street outside. truck ran for about 10 minutes.
Here's some real data on the deck plate install. After two days of close monitoring and driving highway and city, an open airbox yields me intake temperatures that average 5 degrees lower than with it closed. City/highway driving being the highest difference, idle averaging about 4 degrees cooler.
youngrk
