Alright, here is the problem........Just installed a Scion HU and am very happy with the results and ease of installing. However, after everything was put back together, I found that my rear window will not go down. I tried the up/down btn up front, the btn on the remote and the key. Nothing worked. Also, the rear defrost and the rear window wiper does not work. I assume their is some common connection somewhere. I took everything back apart and made sure that are the electrical connector are tight. I also checked the fuses although I wasn't real sure if there is a common fuse. Any Suggestions?
