Greetings,
I have a 2000 Limited 4x4 with 122,000 miles and during deceleration usually at around 40 to 50 miles per hour the engine produces a screeching sound. Now of course, the first thought is a loose belt/s however, we've checked this out both in terms of proper tension & using belt dressing but no luck. I've had the truck since the 17,000 miles and the screeching sound developed at around 70,000 miles and has slowly become worse over time.
Before owning this vehicle, I owned a 1999 SR-5 4x4 and it too developed the same mysterious screech at about the same mileage. My mechanic who specializes in Toyotas doesn't know exactly what it is at this point either so I'm curious if anyone else has run across the same issue and found a solution. The timing belt & water pump have been replaced along with other standard maintenance and that seemed to have no effect on the noise either. Any information or advice would be appreciated. Thank you.
