SCS F-5 wheels 16x8
Any shots comparing the different backspacing for the F5 on a 3rd gen 4runner? I would like the wheels to stick out a bit farther then factory, not sure which backspacing would work best. Thanks!
Here's 305/75/16 with 3.5" bs
2C738466-E9A5-47F6-99EA-9F7DE6919281_zpsn4xdb4m4.jpg~original
AB4E6A74-CD2A-4645-9F92-87665C96F582_zpsadlndi8l.jpg~original
285/75/15 with 4.5" bs
F5_WillG_R2-4.jpg~original
F5_WillG_R2-6.jpg~original
I just wanted to say thanks to SCS and Vin. Received my F5 (17 x 8.5, matte dark bronze) and they look awesome. I will post pics once I get them installed. Standing by for tires.
[MENTION=88453]SCSPerformance[/MENTION] I have a fitment question. Do the F5 17x8.5 have any rubbing issues when mounted on a 5th gen 4Runner? I would be running 266/70/17 G2 Terra Grapplers and have a 1.75 Bilstein lift up front. Thanks!
You might just have to remove your front mud flaps, but for the most part, 265/70/17 will pose very little to no rubbing at all.
This is 17x8.5? Doesn't seem like too much at all. I would like even a little more.
If you have a picture that would be great.
this is the best picture of poke I had on my last rig. an inch or 2 outside the fenders would be in the ball park.
Stick to the 17x8.5 size if you're afraid of having too much poke.
265/70/17 with a 3" lift will look like this.
412E2F3A-DA40-4FC9-9001-D07D01ED7AAC_zpsrfe73mjj.jpg~original
21547306-2824-4688-BF82-08322E40B2A3_zpsiovvg1jn.jpg~original
I'm new here. I have a 93 4Runner.
I'm running oem 15x7" wheels (8 offset) with 32x11.5 BFG. I have OME Shocks SDori Lift 1.5" front and 2" rear.
Which 16" wheel spec would you recommend and tire size?
Thanks!
Thanks!
Personally, I prefer the look of 3.5" bs on a 3rd gen for some wheel/tire poke. If you like more of the flushed look then consider 4.5" bs. Otherwise 3.5" bs with 265/75/16 would look great with a mild 1.5" lift.
Hey Vin
So I have an 05 and just did the lift.. will a 275/70R17 fit on your 17x8.5s? Based on the pix.. whats the offset/bs of them? 4.5 or the 3.5
I've got an 07 SR5 with Icon 2.0 lift. Would like to go with some 16x8's in F5 flat jet black. Wondering what backspacing/offset you'd recommend?
Hey Vin
275s can fit with some minor trimming done. The photo of the silver 4Runner is our 17x8.5 4.3" bs size.
If you want the wheels flushed with the fenders, you'll want 4.5" bs. If you prefer an aggressive look with some poke pass the fenders then consider our 3.5" bs option.
alexaturner
