Thank you.
Bud built hidden winch plate on a 2016 TRD Trail
1st photo is with spacers and a .75 inch thick fairlead
(Getto) looking.
2nd photo is with a inch and a half factor 55 fairlead,
Factor 55 hook and rope gaurd.
[MENTION=132734]MeefZah[/MENTION] and [MENTION=142452]TexasTJ[/MENTION],
Thanks for sharing the writeup and winch fitment info. Very helpful to figure out what to get. I'm goad to see the winch fitment worked for more than the super pricey Zeon Warn models.
Not sure if you have a similar situation, but i figure it's worth checking...did you experience front end sag after adding the 100lb? if yes, how much?
I know there are a lot of moving pieces here (other armor, spring rate etc.), but if you can share your setup and general impact of the +100lb (mount + winch) it would be a helpful reference point! Trying to understand what i'm getting myself into and if new springs will be necessary.
My situation is:
- 6112 Bilstein up front with 600lb springs (standard rate). Set to perch 6 of 7 (almost to max height).
- Front Skid + Filler plate (75lb?)
- Sliders (90lb?)
Current setup is right at the end of too much forward rake (1" forward). Added weight will likely put me over the edge, the question is if I need new springs. I've got another perch (although it's a pain in the ass), but I'd like to avoid new springs if possible.
You cannot. While there is some debate about it, I think (and apparently SDHQ also thinks) that the OEM tie down loops are adequate.
I was just curious, how is the hawser style fairlead holding up to the wire rope?
I always thought roller fairleads with wire and hawser fairleads for synthetic?
Just curious if you have any wear issues or is that not an aluminum hawser?
It's cast iron (and weighs a ton). Holding up fine. Some light rust on the areas where the coating has been worn away by the steel cable but it looks just fine - the rust is inside the "mouth" and not obvious.
It's also the OEM Warn part that they supply with the steel cable.
Great write up thank you. I'm still stuck deciding between this and a lo pro. Does anyone know if you can use the fairlead of the winch as a recovery point (as in being pulled out by someone?). Kind of seems like abusing the winch but it's meant to pull heavy loads like that anyway so I'm not sure.
Ah yea, I've got an older generation VR8000, you must have the newest gen.
Just did it last week.
bumper cut, do this first as it can be your practice run and will never been seen, so it doesn't matter how ugly it is.
For the facia, I just put it back on the bumper (after cutting the bumper) and traced from the inside of the bumper. Cut that out, and then filed it/trimmed a little more, and filed again. Again, these don't have to be perfect, because the fairlead will then cover the hole.
The annoying part is, if the dealer installed the license plate bracket, you now have two holes in the bumper. Hindsight, I would've bought a new Pro facia without LP holes, cut it for the winch, and kept my original one in the attic, in case I ever want to go back to no winch.
Older thread but I'm getting ready to install a winch on my new ORP. This thread was done using my SR5 (I'm the op).
I'm interested in how exactly you installed the fair lead on top of the Pro fascia instead of cutting around it. I just can't figure out how you bolted the fairlead on... since you gotta get behind the bumper to hold the nuts. Can you provide some details on the standoff, the hardware used, and how you bolted up the fairlead, please? Thanks!
those 2 bolts go all the way thru and bolt to the front of the winch I believe. Thats what i've gathered from reading install instructions on a couple of the hidden winch mounts.
