Seat problems
levi.watson
I'm currently replacing the seats in my 89, and I'm having a bear of time working it out. I pulled some leather seats out of a Explorer, and it seemed like they would work fine, but it's not really working out all that great. On the passenger side, the seat doesn't tip forward much more than a 90º, so I need it to slide farther than normal. I was going to just move the stops inside the track, but I don't think that idea will give me enough room to slide. Thoughts? I've been working on this problem for a couple weeks now and it's starting to become tiresome ha. I've considered new seats, but I would rather not go that route as I already pulled these ones out. Maybe new rails?
I remember correctly when you said you got those in the suggestion was that they would not work well because they don't tip for rear passenger entry. Personally I think you should go the BMW route which is proven time and time again to be a better seat option.
If you're dead set on using those seats then you need a secondary slider underneath your current track
These can be purchased from Summit just a simple slider has a latch on one unit that allows the seat to slide forward enough to rear entry. It's all up to you how you get it mounted
Ok, that's good info to know. Do you have any more info on the BMW route? Make/Year etc. for good seat options? Thanks for the help.
I used SR5 seats out of a 2000 4runner in my 1985.
The rear mounting brackets will line up and bolt right in but the front ones will need to be cut off. I cut the old front brackets off and welded them to the track where they needed to be. Not a hard swap, just a few hours.
And I did 1st gen MR2 seats in mine. The fronts lined up perfectly, but the rears needed a little bracket fabbing. Nothing hard though, and they've been solid for close to 10 years now.
early to mid 90's Acura and Honda seats are a nice alternative
Thanks for all the help guys. I'll go back to the junkyard and see what I can find.
These are the 1994'ish Prelude seats I got for $25-30 from pick in pull a few years ago. The car only had 60K in it. I ran them in my 81 Trekker for 4 years. Glad I saved them, i think they will go into my 94.
Driver's seat had a ton of adjustments and very nice for long drives
Thanks for the help everyone, I found some that I think will work today at the yard. Came out of a Dodge Dakota, but these ones are built for having the passenger climb in behind them. Hopefully putting them in Friday.
2001ATL
