Secondary cat delete exhaust?
Samm25
Does anyone have a sound clip of what your V8 4th gen sounds like with the secondary cats removed right before the muffler? Not sure how much difference in sound it’d make with my current exhaust setup.
I did mine a while back when I had an aftermarket muffler and already removed the rear resonator. From what I remember- Sounds sick on startup (louder), noticeable increase of drone, noticeable increase in loudness overall. I don't regret mine, I still have a relatively large muffler and built-in resonator. (Dirty Deeds)
I got one with my CAI but eventually it sorted itself out. I didn't get one for the exhaust.
Nice. Thanks again for the clip. Headed to my local shop in a few hours to get it done!
Sent from my MHA-L29 using Tapatalk
Get ready for a TON of drone. I had his exact same setup minus the CAI and I couldn't stand it. Way way WAY to loud on the freeway. I also had to use eliminators for the rear 02's. I then put two small glasspacks where the rear cats were and it helped a little. I then swapped out the Magnaflow for a Walker Quiet Flow. Is MUCH quieter now and still feel plenty of the power even though the Walker isn't a straight thru. And NO drone.
The drone is known to come from the Magnaflow mufflers.... better off going with something like a Gibson or Dirty Deeds.
I was going to go with a Borla as they are known for being quiet, but I'm 2.5" thru a custom Y to a 3" so I didn't want to keep throwing mufflers at it. I picked the quietest based on reviews and put it on. If it ever goes since the Walkers don't seem to last long I'll try a Borla or Gibson.
I used to drive a straight pipped Camaro so I don't mind the drone haha, I've never really been bothered by it. If it is too much for me though, I might look into some glass packs. I have some here at home that are a no name brand but figure they'll do the job if needed
That's interesting you needed eliminators for the rear o2 sensor. I had a code but it was because one if my front o2 sensors was bad. I looked at your post history and see that was your same experience. When did the eliminators come in?
Ya know...I didn't know if I needed them or not. It's just that all the post I read is that if you run high flow cats, which I am, is that you need these. Was the same back in my Audi days. Gut the precat's and you had to run an eliminator. I never tried running it without it. Be curious to see what happens. Maybe I'll try. My car does seem to run a little rich and I'm wondering being farther it thinks it's getting more air which is making it run rich. What's the A/F mixture on these again? 14.7? I have Torque Pro so I can read it. Just...so many other things that need tended too! HAHA
Possibly the welds weren’t sealed tight enough which is why you got a light? I know when I took the rear cats off my old Camaro, if the welds weren’t done right and there was a leak it would cause a CEL
I never got a light. I never tried running without the eliminators. And the welds are good. I made a template so the cats were welded out of the car when I had to swap out my engine. She runs fine now and I have a long list of honey-dos on her so once i'm done with those other things I'll try it.
Ah, gotcha! What high flow cats are you currently running on it?
