Secret for Mini Maglite Owners
HedgehogOutdoors
*I believe this is for the non-LED models only, someone with the LED model can either confirm or deny this for me*
Well, one of the threads on here asked what we have for survival gear in our 4runners. I went through all my stuff and remembered the bulb in my Mini Maglite is burnt out. It's been that way for months, I just never got around to getting a new bulb. So, I went on Maglite's website, so that I could look for the part number. I found the exploded diagram of the Mini Maglite, and found something that looked like a bulb, but I couldn't tell. I looked at the part name below, and sure enough, it was. So here's how to get at it:
It is inside the tailcap:
This is what you need to be looking at once you remove the tailcap:
Next, you have to pull the spring out. It pulls straight out, doesn't need to be twisted out or anything. *NOTE: when putting the spring back into the tailcap, be sure to seat it in nicely, or else the light may not work. This spring completes the circuit.*
Here is the bulb inside the little red housing:
And it works again!
Even better secret, goto your local bike shop and find one of the 2 or 4 AA powered LED models that they've taken back b/c the chip failed and are cleared to "Destroy and Deduct" from their inventory. Unsloder the 1 to 3 LED's in the front bulb board, stick it in the holder the regular bulb goes in, then unscrew the top cap and lens. Pull the reflector out and either dremel or taper ream the opening until it will clear the LED bulb.
Instant LED mod. :trophy: I just did this to my coworkers. Battery's last forever now and if/when I drop the thing onto pavement while working on the engine or looking underneath at something the bulb doesn't die.
Let me know if you all want pics of what they turned out like.
[EDIT]Disclaimer, give the left over's from the Cateye to the shop to dispose of, Cateye wants to see the parts via pic or in person as actually destroyed.
That would be nice.
To everyone else, the guys on Tacomaworld are very interested in this same thread, they say that the Mini Maglite LED model has the LED soldered in, while the full size can be replaced, so the Mini doesn't have a spare, but the full sized do.
Persimmoncreek-farmer
