1995 4runner 3.0L V6 4x4
156k miles
Rebuilt engine at 155k
Random CEL
Knock sensor code (yes I had the harness and sensor replaced during the rebuild)
Weird issue, but let me take you through my experience. I start my 4 runner up in the morning and I let it run for a few minutes before I take off, all ops normal. (I start down my driveway at a moderate speed before merging onto a country highway. At this time, the check engine light suddenly kicks on when I put my foot into the accelerator. I can literally feel the vehicle fall on its face every time the CEL comes on.) If the CEL doesn't come on after merging onto the highway it USUALLY will later come on eventually (15 minutes or less).
The reason I say usually is because if the CEL does not come on when merge onto I-5 and I can set my cruise control before the CEL comes on, the CEL will stay off until I have to disrupt my cruise control (i.e. speed up after breaking)
So I guess the CEL coming on can somewhat be predicted, which is why I think the problem is electrical and not mechanical. My first research suggested that it could be the harness for the knock sensor, but I just had that replaced. My current thought is that it could be the TPS, because of the frequency of the CEL coming on after I use the accelerator, or a faulty o2 sensor...
But why the knock sensor code??
Forgot to add when the CEL is on I get poor gas mileage and bad engine performance.
Any thoughts or help would be awesome!
Thanks, Eric.
156k miles
Random CEL
Thanks, Eric.
