Sequoia brake rebuild
97t4r81
I've got a set of calipers from an 02 sequoia that need a rebuild before I put them on( tear in one boot). I watched speedy rebuild his and checked his part numbers with camelback and the kits have differant numbers. There are oem rebuild kits available for both tundra and sequoia, with different part numbers. what differences could there be between two calipers(13wl casting both) from vehicle to vehicle? Just seems odd, both calipers look identical and seem to work in the exact same way. Anyone have any direct knowledge of why these have differant numbers/prices for what should be the same stuff? I'm probably going to order the rebuild kit for the sequoia to be as correct as possible, unless there is confirmed use of tundra kit, but I wanted to ask. This is not something I want to make a preventable error on. Thanks, Keith
Sorry you have no input here. You may want to try a Sequoia or Tundra forum search to see if they are compatible.
The old if A=B and B=C then A=C approach is probably best.
Try dealing with just A and B (Tundra and Sequ) instead of A B and C ( Tundra Sequ and 4Runner)
