Falls said:What is TPMS ? I take it pressure monitors ??
Does the wheels in question not have them ? or can you just swap from the stock sport rims ( 17") ??
As far as offset goes , do they stick out further than stock sport rims ??? I never heard that before.
Do the rims from the Tundra and sequoia differ in offset and size. ???? They look the same in appearance .
Guess I'm not really understanding the problem or the thread about TMPS not working on these rims.
Yep, TPMS are Tire Pressure Monitors that are part of your valvestem (and are super expensive!). With other manufacturers I know they've modified their rims to support TPMS by adding weight to the opposite side of the wheel to balance the wheel. The TPMS unit is much heavier than a typical valvestem. This is why I'm being cautious about finding the right set for my gx. I'm not *sure* that the Sequoia rims are different w/TPMS, but I've seen part numbers that suggest the T4r Limited rims are.
Yes, the Sequoia rims have a lower (numerical) offset than the 4r rims (15mm vs 25mm), which means they'll "stick out" 10mm when compared to the OE rims. I think this looks good, and explains why they fill the wheel wells of a 4runner so well.
make sense?
