Sequoia wheel ?
8086bruce
Hi thinking of changing out the rims on my 07 and want a rim with a wider off set than stock and I know the FJ rims are 1/2 wide off set does anyone know if the 17" Sequoia rims have a wider off set as well? Thank you, Bruce
There's someone on this forum that has Sequoia rims on his 4Runner and they look great. They do have a bigger offset and seem perfect for the 4Runner! I can't find the post with pictures, but I'll keep looking... hopefully he'll chime in.
~Doozi
Factory specs...
Sequoia wheel
Rim Diameter: 17 in
Rim Width: 7.50 in
Bolt Pattern (Number of Holes): 6
Bolt Pattern (Pitch Circle Diameter): 139.70 millimeters
Offset: 15 millimeters
Hub Bore: 106.20 millimeters
4Runner wheel
Rim Diameter: 17 in
Rim Width: 7.50 in
Offset: 30 millimeters
