Serious electrical problems! Any help would be great!
GSD_LOVER
So I installed a switch pros and a front facing camera and rear harness over ride now.....
None of my windows will roll up or down, seat heaters wont work rear window wiper and sprayer dont work heat/ac doesnt turn on or light up. Rear window wont roll down either but if i stick my key in the lock it goes up and down. And the lights for the seat heaters work but no heat.
I checked the fuses and they seem to be fine. Is there a ground, clip, harness or something all these circuits are controlled by I could have nocked loose?
This really sucks. Any help would be greatly appreciated.
Not that this should be interpreted as advice but you may be stuck reversing your entire installation in steps, testing as you go, until you solve your own problem. Something you did has your comfort module/stock wiring flipped-out. Hopefully someone with real knowledge can help you, that doesn't sound like fun.
It was the 10 amp ecu number 2 fuse. all is fixed now. I guess I missed it when I was testing them. I will leave this up so hopefully it helps someone else out in the future.
I would check that everything else works. Even stuff you don't use often. Better to know now and have time to fix any problems instead of discovering when you really need it. Also, wiring is best done and continuity checked with the battery disconnected. Then power on checks; followed by function checks.
D'Angelo
