1999 4runner with 265000 miles on it, was running great.
Just started to have issue, I noticed the idle would go up and down a bit while idling. That went away. Then it started to shake taking off and driving, like only few cylinders firing under load or tranny. I got around the block and it started to smell a bit...something was burning.
The fluids were on the low side...low oil, low tranny, and low coolant. I had checked it all two months back. I put more fluids in, didn't help. The oil looks a bit on the frothy/bubbly and a bit dark. Makes me think leak.
Is this the tranny going out? A leak inside like the water pump...which his due to be replaced in 5k miles? Any ideas? Shift solenoid?
I see no puddles under the truck.
I'll take to the shop on this one but not sure if I should take to tranny shop first. It has to be towed.
The rear frame has some rust areas that need repaired ...a few thousand. So, it may not be worthy of repair. How to dispose of a 4runner if this turns out to be pricy fix? Has fresh wheels and brakes...sad...what a great truck it's been!
