Shifter linkage location?
depth
2007 v8 4wd.
Currently installing 4crawlers 1.5" bl... Having trouble finding the shifter linkage bolt that I need to loosen. Called a dealer and the mechanic said it's just a cable. Is there no shifter linkage bolt on the 07s? Or am I just unable to find it?
Everything else has been pretty straightforward so far.
It's just a cable that runs from the shifter assembly to the transmission. You're not gonna stretch it with a 1.5" body lift. That cable has plenty of slack for a 1.5" BL. I don't think they've used physical linkages to the automatic trans in a long time.
H.Sikina
