Shop recommendation in Denver
Herculean T4R
My rear axle seals are slightly leaking. Need recommendation of a shop that is capable of doing the press work. I can take the axles out but don't have the tools and press to press in bearings and new parts. Denver and surrounding areas.
The Toy Shop
I strongly endorse Greg at The Toy Shop!
If theyre only leaking a little and the diff breather is all gunked up sometimes cleaning that out will make em stop leaking. Two most common reasons ive seen for em to leak is bearing wearing out (then you gotta bite the bullet) and pressure building up in the diff and pushing gear oil through the seals. Get your breather working right and thatll stop happening as long as it hasnt been going on forever.
[MENTION=116244]Herculean T4R[/MENTION]
If you're up around Boulder the Team at Slipstream Autocare has treated my 97 Tacoma and SO's Camry great for the last few years.
(Starter & Clutch replacement, Maint on the Tacoma, Likely be doing a full suspension replacement soon. Don't remember what all my SO had done. )
https://slipstreamautocare.com
4770 Sterling Dr
Boulder, CO 80301
(303) 449-9843
Boort
Smooth Ride Auto - 303.920.2951
Phil is a 17 year Toyota certified mechanic with his own shop
seltzernator
