Fro-Runner
The time has come for me to make a decision as I only have 3 days left until my 4Runner becomes 36 mos old. It only has 23k miles on the speedo.
Here's what I must decide on. The dealer offers a 30k/3yr/36 mos service for $399. This service includes: tranny flush, oil change, tire rotation, air and cabin filter replacement, differential fluid change, lube chassis including propeller shaft, adjust brakes including E-brake, battery service, coolant change and replace the spark plugs but get a load of this (resistor plugs cost $35 extra, Platinum $50, and Iridium $120). Now that's a whooping $520 plus tax if I want the Iridium plugs in my 6 cyl engine. Wow'zers! :awais:
I believe Shaun sells the 7yr/60k ext warranty on here for around $600 plus tax. I've already switched to synthetic oil and plan to do the same with the tranny and diff oils. I have the homemade cabin filter in place along with two Fram air filter changes already (every 10k mls for cabin and engine air filters). I want to switch the coolant over to the green stuff anyways and this would easily be a drain, fill with water, add in a bottle of super flush, run engine for 5 mins then drain and refill with prestone 50/50 mix. I have a grease gun but need to get the rubber hose model and a tube of green grease. Battery cables are easy to clean and the brakes shoes can be replaced at about 50k (I baby my big baby). Finally, I plan on adding a lift anyways either the Donahoe coils F&R or by just saving money and installing the Old man EMU system in the fall.
What do you folks here think? Should I spend the money with Shaun on a ext warranty? Or safisfy Toyota's maintenence schedule and get the 36k service for $399 with the tranny and radiator flushes minus the plugs installed?
