Should I jump on it??
I can't tell from the listing. He does say that it will bolt up and align so it sounds like the mounting brackets are included.
Jump, jump!
I'm gonna hold out till Friday (payday) if he still had it by then... Then it was meant to be
I spoke to him he said "*The rear of the top flange is wavy across the middle, there is a tiny crease on the bottom, a small dent on the pass side around the turn signal, and some scratches.. The structure of the bumper held solid, mounting locations didn't move a bit" and "It's really not in that bad of shape, I'd keep running it if I hadn't already built a replacement ;)"
I just though about how lucky he is /: then said I'll take it if you have it Friday :D
id be alllll over that, then you dont have to worry about putting the first ding on er, plus save 800 bucks.
I cant fit 15's on my runner with stock brakes.. but i know this differed on different models
You better get this or I'm driving to Tomball (where ever that is) to get it first.
I would buy it if I were you. I personally know Justin and he is a super stand up guy. I was actually going to be purchasing this for my tacoma but I told him to sell it cause it would be a couple months before I was back in Houston. He also is the welder at Schrockworks so he knows his stuff. Good luck man
I'd call the guy and tell him you'll give him full price if he holds it until Friday...or maybe give him $50 now and the rest on Friday. I know I've done that with people. Not everyone has the cash at that moment, I know I haven't sometimes. That way you don't lose out on it.
So what's the verdict?
As y'all may know I've started over heating.....
I replaced the rad cap along with the thermo
And
I'm still over heating.
I've done my research and I think it's my head gasket (I'll change both since I'm there)
So I've have to save my money at the moment :,(
HAVE A IT HOUSTON GUYS, if it isn't gone already.
And
That sucks man, especially when a sick deal like that comes along. Hopefully everything works out for you.
And
360K on a radiator with brown water sounds like rust got the better of you. Before you rip the heads off and spend big $$$$$$$$, spend $150 on a radiator and heater core. Chances are the rust got the heater core and the radiator. Heater core could be the reason you smell anti-freeze inside. Some things to determine before you take the heads off. Change the radiator and heater core these are needed repairs with 360k. Have the system pressure tested. Is the engine missing(coolant in the cylinder), is the coolant getting hot and boiling over quickly or slowly(quickly=exhaust gases in coolant, slowly=partial blockage is system). Do you have water in the oil(looks like chocolate milk) or oil in your water(gelatin looking chocolate shake). Is your vehicle smoking with sweet exhaust smell(burning coolant). Go down the list start with the least expensive things first(Cap, Tstat, Heater Core, Radiator, Water Pump then Head Gaskets).
