Shrockworks 5th Gen 4Runner Front Bumper
Looks like a pair of Lightforce 240 Blitz would fit nicely in the middle of that grill! Any chance for a tab or two, maybe even a spot for an aerial? Sure would hate to grind off some fancy pants 3 coat powder coating to weld on some tabs.
Will the powder coat pictures be up before the end of promo? Also do aftermarket lights fit on the bumper or the original OEM brackets?
What is the wait time for production after ordered?
On the timing, I dont know, it will be close. If you want to see what the PC looks like, just look at the 3rd or 4th gen pics.
Our PC is extremely durable. It is a multi-stage process. The prep work done right takes 3x longer than the actual powder coating. That's why lot's of places just phosphate wash it the spray it. Ours is washed, then baked to solidify any oils in cracks, then sand blasted, then put in the oven for a second time and then powder coated with the metal hot. Spraying it hot allows approx a 2x thicker coat than spraying cold and also gets in the cracks and crevices much better.
Factory fogs bolt into special brackets on our bumper. Those are the factory fogs in the pics.
12 weeks to ship from order date.
I keep looking at it and I cant decide if I want the hoops on it. I was thinking none or just the center hoop. Any body have an opinion either way on it?
For me it's about armoring my rig. I'd go with hoops. If you hit a deer you'd wish you had them.
any pics of it painted?
better shots of the attachment to frame?
Body panels do NOT need to be cut?? You have a replacement panel for under lights
Not yet, will have more pics next week.
It attaches just like our 4th gen. and it has been proven rock solid over the years.
No cutting body panels or stock bumper. The white part under the headlights in the pics are our trim pieces that come with the bumper.
Is there access to get to the winch to switch it to free spool and back ? Where does the solenoid mount ? How would you plug in the winch remote ? Any more details on the winch mounting ?
Thanks.
Thanks.
Is there room to mount a Warn 9.5ti or 9.5cti?
cant one of you just photoshop it black?
I just tried, buy it's above my photoshop pay grade....
I hope you don't mind... I had some time to kill.
Original:
And Blackened:
If I order, actually when, is it possible to have a hole drilled on the driver side for a CB Antennae? Say a firestik of some sort? If yes how can I specify on my order sheet?
Can't wait.
Any reason you left the fender liner so low? Is this as far back as we could safely cut our fenders without stuff getting in the engine bay?
Otherwise, the bumper looks great! You guys did a really good job in the styling.
peacefulpiranha
