Shrockworks Sliders Install
G.I.G.
I posted this under my build thread, but thought it would be useful here for anyone who is planning on getting a set of Shrockworks sliders. Feel free to PM me with questions. Cheers.
I installed my Shrockworks sliders with the help of a friend today. This is definitely a 2-man job, so I'm glad I waited until I could enlist the help of a friend.
As you probably already know, the stock step tubes are very flimsy and will buckle under even a little pressure on a trail. Below are a couple of pics of the stock step tubes, illustrating how much abuse they took while they were on there.
IMG_6770.jpg~original
IMG_6769.jpg~original
Installing the sliders were a PITA. I followed the directions, had the appropriate tools, and had an extra set of hands. Still, this ended up being an 8 hour job that easily could have take less than 2. Let me explain....
The front U-brackets on both sliders do not line up well on either side. Towards the front of the vehicle, the frame gets wider and curves in slightly before it curves up. Shrockworks designed the slider so that the front cross member is angled back slightly. It would have been much more efficient if they just moved that cross member back about an inch/inch and a half and kept it straight, as there is nothing on either side that would get in the way and would make for a much more efficient design.
We tried moving the sliders further forward, further back, but still came up with the same problem with the front U-bracket: we could not get the bolt through to the other side. Plus, since the frame widens, when you jack the sliders into place, the frame pushes the U-bracket outwards so instead of looking like |__| it ends up looking like \__/ so you cannot get the bolt through to the other side. Shrockworks does make the front U-bracket wider and supplies a longer bolt for the front, but it was not wide enough. I don't know if it was the frame on my particular 4Runner or the sliders Shrockworks sent me or a combination of the two, but from searching this forum and others (including Toyota120), I am not the first person who has encountered this issue.
We ended up making a trip to Ace Hardware to pick up a thinner bolt (1/4 inch) and bent it slightly so it could make it through to the other side. This is a bit of a shortcut, but the middle and rear bolts are so rock solid, I don't feel like this will compromise the integrity of the sliders. The bolts basically hold the sliders in place. Most impacts are going to be pushing the sliders towards the frame, and not pulling on the bolts themselves.
Regardless, we got them on and I am pleased with the end result. I drove my 4Runner around after the install and everything seems to be very tight and I did not hear anything wiggle around. I will get under it again here in the next week or two to re-torque everything once I've put some miles on it, but I don't think these sliders are going anywhere.
IMG_6902.jpg~original
IMG_6907.jpg~original
IMG_6904.jpg~original
I'm happy with the final result, but the true test will be on the trails. From everything I've read, these should hold up great.
G.I.G.
Glad to see you got them on - your truck looks great. To bad it was such a PITA, but it makes me feel good I paid Slee to put mine on!
Ed
G.I.G.
Ed
Thanks, Ed. I had initially called Slee for a quote to install them but they would not give me a price over the phone. I should have just asked you what they charged you for the install. I thought it was a little sketchy that they wouldn't give me an estimate over the phone on something they have done many times before, so I decided to do it myself. So it only ended up costing me 8 hours of my time, dinner for my buddy, a sore neck, and a swollen thumb (I railed my thumb on one of the cross members while taking a whack at it with a rubber mallet :)). No complaints though, I'm glad I got them on finally!
Yeah, I could of told you the price. Oh well, they're on and you have the satisfaction of having done it yourself in spite of the sore thumb and neck :thumb3:
Ed
Shrockworks Sliders
Hey G.I.G.
The sliders look awesome. I just recently installed my Shrockworks sliders and they are a bit of a pita. I did it by myself which was challenging but I mostly had issues with the rear brackets with the limited access space to the bolts/nuts. I bet its even more frustrating when you can't actually get the bolt through to the other side. It took me about 5 hours to do but the end product is pretty sick. I can't wait to see how they hold up out on the trail.
Sean
Thanks, Sean. I'm looking forward to getting them out on a trail. I have no doubt they will do great.
They look great! Should match you bumper perfectly ;)
Do you have pics of the underside after the sliders are bolted on? Also, did you compare the CBI and Demello Bolt-on's as well? Feedback or thoughts?
Ha, the bumper is going to be a while!....
I did check out the Demollo's but not the CBI sliders. The price of the Demollo bolt-on sliders and the Shrockworks is very close and the construction/quality looks to be similar. I had it narrowed down to Shrockworks and Rocky Road, but ended up going with Shrockworks with the reviews I've read.
I'm happy with the Shorckworks....now that I have them on. I may have been cursing them while I was under my 4Runner, but we've since made up. :)
I had the same problem two times installing SW sliders. The second time round we bought a longer bolt, pulled the front brackets in, clamped them, then pulled the bolt out and put the SW one in. Darn things never moved in several years. They are a great investment and the PITA instal is forgotten in time. Enjoy them!
Southshore
