Shutter at 55 and up
check the output shaft of the transfer case for up/down movement - there's a bearing there that can be an issue.
To what extent would you say? Would any movement up/down be bad?
I'm curious, I checked that and it had some up/down movement and I took it to a friend to look at and he said its fine, a little movement is okay. He's a lead mechanic in a heavy diesel shop so I'm pretty confident he knows what he is talking about.
I feel like he actually may be wrong in this case and the output shaft bearing is bad and that's what is causing my vibration
Mine has 3/8" up/down. Way too much, IMO - mimics a bad u-joint
There should be zero play in the TC output (same with the diff pinion input). They are both riding on pre-loaded bearings.
(there will be some play in rotation - that is normal)
-Charlie
AlaskaRuss
